I’m trying to locate ducts and pipes in my project.
I noticed that it’s easier to locate ducts and pipes in levels then in zones, spaces … (2D).
In order to do so, i tried to use element.location node to be able to get pipe’s coordinate, but when i connect the results with the boudingBox.Contains i get an empty list.
Is there an other way to locate ducts and pipe in spaces ?
I’ve changed the lacing :), and i’m trying now to append a new parameter that can indicate where the duct/pipe is located.
My goal is that the parameter “localisation” will copy the space name automatically.
I’ve created two spaces in my project and i used Element.setparameterbyname to do so, but i didn’t get the expected results. there are just two pipes of which the location parameter have been named and not correctly :(.
