Local Printers Names Crashes Revit
#1
Hi All,
I’m trying to use the Local Printers Names from the Archi-Lab package but it crashes Revit 2016 (Dynamo 1.3.0).
Any Idea why?
#2
Does it also happen in sandbox mode? If so can you open the node directly? I believe there is Python in it, so try running the Python code contained in the custom node in Iron Python directly and report your results.
#3
@JacobSmall Apologies for the late reply.
Yes it also happens if I use the python code in the node.
#4
I’m having the same issue. Any ideas on how it can be fixed?
#5
Just type your printer name in a codeblock or in a string.
