Loading Materials From Template file
Hello Everyone,
I was trying to create a dynamo script to transfer materials and it’s properties from the template file. using some pyrhon coding in the script but when the script is running it’s giving some error msg as in the screeshot. can anyone help me to fix the issue.
loadMaterials_fromTemplateFilePath.dyn (7.8 KB)
Hi @rajendra.ganesh
start by learning python, you will find information on your error here
You can I sent with tabs. Or you can indent with spaces. You cannot mix.
Enable the ‘show white space’ feature in the Python section of the preferences to identify the discrepancies.
