Hello forum members,
I try to load the Assembly Code Table into my Revit Project before i can assign the Assembly Codes per family type. But with the LoadFrom for the table I failed. Dynamo give the error:
“TypeError: expected KeyBasedTreeEntryTable, got type”
Can someone help me out. Thanx in advance!
http://www.revitapidocs.com/2017/51da265d-a879-61dd-3b59-b919bf2645f4.htm
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
path = IN[0]
table = KeyBasedTreeEntryTable.LoadFrom(AssemblyCodeTable, path, loadResults)
TransactionManager.Instance.ForceCloseTransaction()
OUT = table
With the following code you are able to load the AssemblyCodeTable from another path.
You can also use the script for KeynoteTable: simply change “AssemblyCodeTable” to “KeynoteTable” in the script.
// locate your .txt file with the File Path node
filepath = IN[0]
p = ModelPathUtils.ConvertUserVisiblePathToModelPath(filepath)
s = ExternalResourceReference.CreateLocalResource(doc, ExternalResourceTypes.BuiltInExternalResourceTypes.AssemblyCodeTable, p, PathType.Absolute);
AssemblyCodeTable.GetAssemblyCodeTable(doc).LoadFrom(s, KeyBasedTreeEntriesLoadResults());
OUT = s
