Set Assembly Code file
Does someone know how to set the Assembly Code file with Dynamo in Revit.
Only found the node how to get the file path…
http://dynamobim.org/forums/topic/get-assembly-code-settings-in-python/
I don’t even know what a Assembly Code Table is, but the
AssemblyCodeTable Class in the Revit API has only got one Method, and that’s the GetAssemblyCodeTable Method
http://www.revitapidocs.com/2016/26b23f25-ef12-5368-3f4b-6097f93ce312.htm
That makes me think it’s not possible to set it. Someone else might be able to give a more certain answer than me.
Assembly code is a UNIFORMAT classification (Alphanumeric string) for categorizing the built environment. Anything constructed can be classified by these codes.
@Jeremy_Tammik - Any suggestions on how to SET assembly code in PYHTON? (Thanks in advance : )
I am having a similar issue- ran across “UNIFORMAT_CODE” as a built in parameter - see section under:
if param.lower()=="assembly code":
    outSub.append("UNIFORMAT_CODE:")
     element.SetParameterByName(BuiltInParameter.UNIFORMAT_CODE,dat[hI])	#p=header/param name, dat[i]     corresponding data at index
     outSub.append("BuiltInParamSuccess!")
This is not working either (Correctly formatted code below).
# Default imports
clr.AddReference("RevitAPI")
elements = IN[0]	##Elements in the mode
headers = IN[1]		##Headers for reference
data = IN[2]		##Data LIST of values for PARAMS.
###Initialize
out=[]
outMain=[]
outSub=[]
found=0
##Find "MARK" Position from headers
for markPos, mark in enumerate(headers):
	if mark=='Mark':			##Found mark in headers proceed
		found=1
		break				##BREAK loop with current header index
if found==1:				##NEED better system of parameters to key-in on other than mark with a "+"
	for element in elements:								##Step through all the elements provided
		emark=element.GetParameterValueByName('Mark')		##Get the mark of the current element
		for dat in data:									##For each of the list(Data points) provided
			if dat[markPos]==emark:							##If the data in the [markpos]
															##(Which is the mark we are looking for) matches the
															##Current elements mark - we have a match to push data
				outMain=[]									##Reset the list collector for reporting
				for hI, param in enumerate(headers):		##hI count based on header Information to corresponding data
															##-For parameters that are headers in the file
					outSub=[]								##Reset the list collector for reporting
					try:
						outSub.append(param)				##Report parameter to push
						outSub.append(dat[hI])				##Report data psuhed to param
						element.SetParameterByName(param,dat[hI])	#p=header/param name, dat[i] corresponding data at index<<-##Does nothing for "Assembly Code"
						outSub.append("SetParam Success!")	##If it reaches here it was successful!
					except:									##Error occured above
						outSub.append("Checking BuiltInParameters:")
						try:								##Attempt to unwrap to set type param
							#outSub.append("Unwrap:")
							#element=UnwrapElement(eleent)[0]
						except:
							outSub.append("ERROR in unwrap_set")		        #Add "error" to the return if it flakes
					##outMain.append(element)				##Append element to outMain
					outMain.append(outSub)					##Append Parameters success/fail
				out.append(outMain)
out.insert(0,[["****Tab must be 'Sheet1'***************\n****'Mark' in row 1 must be defined****"]])
OUT=out
I tried setting by name for “Assembly Code” in the 1st attempt to se in the code and it failed.
Got the idea for built-in parameters from:
https://forums.autodesk.com/t5/revit-api-forum/assembly-code-in-system-families/td-p/4790573
AND
really need to know how to set family TYPE parameters in Python- as well I suspect the “Assembly Code/Uniformat” is a special parameter.
Here is how to set a builtinparameter (typeparameter) with python. This is untested code.
# Import Revit API
clr.AddReference('RevitAPI')
# Input
element = UnwrapElement(IN[0])
valueToSet = IN[1]
#Get the type
elementType = doc.GetElement(element.GetTypeId())
# Get the parameter
parameter = elementType.get_Parameter(BuiltInParameter.UNIFORMAT_CODE)
 #Set the parameter in a Transaction
parameter.Set(valueToSet)
OUT = 0
Much Obliged!
Will test and debug it and then push it back to the forum.
Thanks!
Ron Allen | B+P BIM Manager - Rocky Mountain Area | Revit BIM ARCH.IV.NCARB.IDP | D 1-303-740-2716 | Ron.Allen@AECOM.commailto:Ron.Allen@AECOM.com | AECOM | www.AECOM.comhttp://www.aecom.com/ Denver
PPlease consider the environment before printing this e-mail.
Admittedly I don’t know how unwrap works… so I had to adapt the former part of the code and add the unwrap later- still errors out setting the parameter (Can you unwrap an element?)
in the 2nd TRY there is the ### Unifromat scan:
ele=UnwrapElement(element)
#Get the type	##UNIFORMAT SET
elementType = doc.GetElement(ele.GetTypeId())
# Get the parameter
parameter = elementType.get_Parameter(BuiltInParameter.UNIFORMAT_CODE)	##
parameter.Set(data[hI])
Entire code:
# Default imports
import Revit									#################################
clr.ImportExtensions(Revit.GeometryConversion)	#################################
clr.ImportExtensions(Revit.Elements)			#################################
# Import DocumentManager and TransactionManager##################################
clr.AddReference('RevitServices')				#################################
import RevitServices							#################################
from RevitServices.Persistence import DocumentManager	#########################
from RevitServices.Transactions import TransactionManager	#####################
doc = DocumentManager.Instance.CurrentDBDocument	#############################
data = IN[2]			##Data
###Initialize
out=[]
outMain=[]
outSub=[]
found=0
		found=1
if found==1:				##Consider adding additional parameters to key-in on other than mark
		for dat in data:
				outMain=[]
				for hI, param in enumerate(headers):		##hI count based on header to corresponding data For parameters that are headers in the file
					outSub=[]
					try:
						outSub.append("SetParam Success! \t")
					except:
						outSub.append("ERROR in element.SetParameterByName \t")		        #Add "error" to the return if it flakes
						try:	###################################################################### Unifromat scan
							ele=UnwrapElement(element)	##############################################
							#Get the type	########################################################## UNIFORMAT SET
							elementType = doc.GetElement(ele.GetTypeId())	######################
							# Get the parameter									######################
						except:
							outSub.append("ERROR in set element.GetTypeId() (Uniformat) \t")
				out.append(outMain)
OUT=out
Your unwrapping looks fine. While troubleshooting, it would be better to remove the try-except blocks to see what error messages you get.
File “”, line 55, in
NameError: name ‘BuiltInParameter’ is not defined
Are you missing a reference?
# Import Revit API
Yep- Missed the import
Now it is a different error:
File “”, line 58, in
TypeError: expected int, got list
    # Default imports
data = IN[2]			##Data
###Initialize
out=[]
outMain=[]
outSub=[]
found=0
		found=1
		for dat in data:
				outMain=[]
					outSub=[]
					try:
					except:
						except:
				out.append(outMain)
OUT=out
Cleared the othe rmessage with:
parameter.Set(str(data[hI][0]))
for the data…
Almost have it- posting the wrong data to the assembly code but it is setting it …
Finally! Thanks for your help!
# Default imports
from Autodesk.Revit.DB import *					#################################
data = IN[2]			##Data
###Initialize
out=[]
outMain=[]
outSub=[]
found=0
		found=1
		for dat in data:
				outMain=[]
					outSub=[]
					try:
						outSub.append(param)						###ADD PARAMS TO Output list
						outSub.append(dat[hI])				###ADD TABS + Data to output list
						element.SetParameterByName(param,dat[hI])	###Attempt set data header/param name, dat[i] corresponding data at index
						outSub.append("SetParam Success!")	###If it succeedes report it
					except:											### If if failed...################################################
						if param == "Assembly Code":				##SPECIAL ODD-BALL CASE for SYSTEM TYPE PARAM (Assembly Code)####
							try:	##################################Assembly Code = Unifromat scan
								#Get the type	###################### (UNIFORMAT TYPE param)
								# Get the parameter###################
								#Set the parameter in a Transaction###
								parameter.Set(str(dat[hI]))			##FROM THE current DAT line of DATA return the data from the hI Index position in the list
								#Set the parameter end  Transaction###
								outSub.append("Set ASSEMBLY CODE Param Success!")
							except:
								outSub.append("ERROR set element.GetTypeId() (Uniformat)")
				out.append(outMain)
OUT=out
Hello Ron. I really apprieciate your work, but can you make your script more understandable? What do you mean by the folowing parameters?
data = IN[2] ##Data
Maybe you can add some printcreens from your Dynamo workaround to this post?
thanx!
elements = IN[0] ##Elements in the model - Elements to run the script with (1d List)
headers = IN[1] ##Headers for reference - The headers stripped out from the excel file (Also the Revit PARAMETER Names)(1d list)
data = IN[2] ##Data - The remaining excel rows of data.(List of list - 2d list)
thurevit3 , Did you solve the problem of the question? I would also like to set the Assembly Code with Dynamo in Revit
Create a Python Script with the following Code:
With a filepath as input, (referring to the location of the .txt file) this should do the work
from Autodesk.Revit.DB import*
app = uiapp.Application
filepath = UnwrapElement(IN[0])
p = ModelPathUtils.ConvertUserVisiblePathToModelPath(filepath)
s = ExternalResourceReference.CreateLocalResource(doc, ExternalResourceTypes.BuiltInExternalResourceTypes.AssemblyCodeTable, p, PathType.Absolute);
AssemblyCodeTable.GetAssemblyCodeTable(doc).LoadFrom(s, KeyBasedTreeEntriesLoadResults());
TransactionManager.Instance.ForceCloseTransaction()
OUT = s.GetReferenceInformation()
