Hello People, I want to load 1 lookup table in multiple families in one go
I have found a orchid package were i can use some nodes but i don’t get it running.
Can some one help me. I don’t get an error but there is something wrong with my script. See picture below for what i have now.
Hi @Olaf_Kappert,
The FamilyDocument Open node needs a family instance or a family to be able to return a family document and not a filepath.
Since you are using an Orchid node, the other nodes must also come from Orchid.
From what I know there is no compatibility between Orchids (family) documents and other custom nodes / packages.
Yes Alban…Orchid is a closed system
Oke, Thank you very much. Then i will check if i can make this script with only orchid nodes
Hi @Olaf_Kappert , if you go with an Orchid solution…can you find it all here, under sample…
Who can help me further with my script. I don’t get any errors but the lookup table isn’t loaded in my families. I have blur my my path a bit, i hope that is not confusing.
What is wrong with this script, I want import the lookup table that is in the string for it.
@erfajo, can you help me maybe or somebody else.
Who knows what i’m doing wrong. The nodes are all orchid nodes but i don’t get the lookpu table in it. It saved the family but i don’t see any changes in it.
Hello @Olaf_Kappert
here is an example with Python
import sys
import System
clr.AddReference('RevitAPI')
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
fampaths = toList(IN[0])
csvPath = IN[1]
success = []
TransactionManager.Instance.ForceCloseTransaction()
for path in fampaths:
famdoc = app.OpenDocumentFile(path)
t = Transaction(famdoc)
t.Start('import_table')
family = famdoc.OwnerFamily
# create SizeTableManager
FamilySizeTableManager.CreateFamilySizeTableManager(famdoc, family.Id)
familySizeTableManager = FamilySizeTableManager.GetFamilySizeTableManager(famdoc, family.Id)
famSizeErrorInfo = FamilySizeTableErrorInfo()
familySizeTableManager.ImportSizeTable(famdoc, csvPath, famSizeErrorInfo)
famdoc.Regenerate()
if famSizeErrorInfo.FamilySizeTableErrorType == FamilySizeTableErrorType.Undefined:
success.append("Success")
t.Commit()
elif famSizeErrorInfo.FamilySizeTableErrorType == FamilySizeTableErrorType.CannotParseColumnHeader:
success.append("Failed : {}, InvalidColumnIndex : {}".format(famSizeErrorInfo.FamilySizeTableErrorType.ToString(), famSizeErrorInfo.InvalidColumnIndex))
t.RollBack()
success.append("Failed : {}".format(famSizeErrorInfo.FamilySizeTableErrorType.ToString()))
t.RollBack()
t.Dispose()
famdoc.Close(True)
famdoc.Dispose()
OUT = success
Edit post 15/05/2022
fix the output message when famSizeErrorInfo is not empty
