Using multiple search for items in “String Contains
Hey, I do see this issue has been addressed before, but I don’t really get it to work for me.
When I use just a single word in my string node (exclude1) the List.Filter node separate sjekkliste A1 and sjekkliste A2 - just what I want, but when I change the searchFor in the String.Contains node to a list the List.Filter node does not work anymore.
How do I remove items from a list based on a another list?
@brageCRRV7 ,
check out this topic … when you look for multible items
KR
Andreas
hi! is this what you are looking for?
You should just set the lacing to cross product when checking with another list and then use anyTrue with a longest lacing. You will get the bool mask to filter your initial list :slight_smile:
Thanks for the fast replay!
I did use the node List.SetDifference, and it worked. The order of list 1 and list 2 had something to say.
Yeap, that’s also an option :slight_smile:
