List.filter filter numbers
How can I filter out the integers in the list with the following scheme:
I don’t understand what the input needs to be for the condition node. List.removeifnot can only be used to filter out strings?
@kboschJGDNZ ,
i like group by function!
KR
Andreas
Great thanks! That did the trick.
Beware that the order could change because it sorts and groups by the first occurences of that key in your input.
You should use List.RemoveIfNot and use the exact string the object.type node shows as the type for an integer
@kboschJGDNZ , @Daan
thats fine!
What needs to be inserted in the code block when you need the integers instead?
Something like this ?
Yeah that’s exactly what I was looking for!
@kboschJGDNZ ,
:wink:
