Hi Everyone
do anyone know any node by which i can select linked civil 3d toposurface in my revit and convert to polysurface.
i am using revit 2019.
thanks in advance.
Hi Everyone
thanks in advance.
1- Select model element āto select the linked toposurfaceā.
2- Follow below pic.
Try using element. Geometry before topography. Mesh
Sorry, but a linked Civil 3d topo is a special element and its geometry canāt be extracted from the API as far as I know. Therefore not by Dynamo either.
First I am a total Dynamo beginner.
I use the Revit INSERT, LINK TOPOGRAPHY command to link to a Civil 3D topography via ADC / BIM360. Then I use the script I leaned at my Dynamo class, it works fine with Revit topo:
I receive the error message: Warning: Internal error, please report: Dereferencing a non-pointer.
Is it still not possible?
Peter
Topography Links can be extracted using Dynamo
The ātrickā is Topography Surfaces can be Selected using TAB cycling.
Using Select Model Element -
Rather selecting the TopographyLink (First Option), You can TAB Cycle in Revit to select the Model Element TopographySurface (Second Option)
Yes, but you canāt extract the geometry for use in Dynamo to the extent of my knowledge. Am I wrong?
