Hello, how’s it going? Good morning:
I want a planning table where the measurements of the sheets are, the problem is that the measurements (width and length) are in the category of title blocks.
I have created two type parameters that I have applied to sheets category, and I want the values of the measures of the title blocks appear in these parameters.
Let’s see if any of you can help me.
The problem I detect is that when dynamo lists the elements, the order of the sheets and the order of the title blocks is not the same, so I use an order that allows me to relate both elements, ie the sheet with nº 01 and the title block whose plane number is 01, or does not assign me the dimensions correctly. On the other hand it has occurred to me to order the list of elements that comes out of the sheets and that of the title block but when I use the command “Element.SetParameterByName” it does not detect the ordered lists, I do not know if any node that allows transforms a list in elements.
Thanks greetings.
jejejeje
