I am trying to get layout names of several dwgs. I’m using LINKDWG package and I can get the layouts to show up, but only for the current dwg that I’m accessing. Can this be done???
This graph may look messy, but only because I’m trying a bunch of different things to see if I can get it to work.
I’m using 2023
You can use the camber package to get the paper space blocks in an external document. Use “External Document”->“External Blocks”->“Is Layout”->“FilterByBoolMask” the external blocks. This will give you the paper space blocks. But @zachri.jensen how do you get the name of corresponding layout?
Hi @SMorykin,
So long as you’re working with things in external drawings, you might check out the Camber package under the “External” shelf. There’s some handy stuff in there. As far as layouts go, it’s been on my list to add that to the package for awhile. I can bump that up in the priority list and put something together for you.
Other alternative is use the layout manager in a python node. Although, if i were to write the code it would have to open each drawing to get the layout names. Not sure how else to do it.
Do some research on side databases. Good weekend reading
Still have to do research on side databases. Here is a solution for now @SMorykin. But it has to open the drawings for a moment to grab the layout names. (Has to be python2 not 3)
import os
import re
# Add Assemblies for AutoCAD APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
import Autodesk.AutoCAD.ApplicationServices.DocumentCollectionExtension
DWGPaths = IN[0]
allLayoutNames = []
#Real Code
for DWGPath in DWGPaths:
adoc = DocumentCollectionExtension.Open(acapp.DocumentManager, DWGPath, False)
with adoc.LockDocument():
with adoc.Database as db:
layoutNames = []
layoutDict = t.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite)
for layout in layoutDict:
if "Model" not in layout.Key:
layoutNames.append(layout.Key)
for layoutName in layoutNames:
allLayoutNames.append(layoutName)
t.Commit()
pass
if adoc:
DocumentExtension.CloseAndSave(adoc, DWGPath)
OUT = allLayoutNames
GetLayoutNames.dyn (15.4 KB)
@SMorykin,
There are nodes for this in Camber v4.1.0.
