Layouts to DWG
Hi! I have a .DWG file with multiple layouts, each with a specific name. How can I create a Dynamo script that separates the layouts into different .DWG files, so that each file contains the common model space and only one layout? I already have a .LISP file, but it is too slow and always opens a dialog box saying “Include AutoCAD Map information in the export?” and I have to click “YES” everytime, so I can’t let the .LISP run at night, for example.
This is the .LISP file
;;; LayoutsToDwgs.lsp
;;; Created 2000-03-27
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2012 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
;;; 2003-12-12 Sets UCS to world in model space
;;; to avoid problem with wblock
;;; 2011-06-06 Excludes empty layouts
;;; 2012-06-01 Handle Map prompt with WBLOCK
;;; Include AutoCAD Map information in the export? [Yes/No] :
;;; 2013-03-04 Added _ on some commands to internationalize it
;;; For AutoCAD 2000, 2000i, 2002, 2004, 2005,
;;; 2006, 2007, 2008, 2009, 2011, 2012, 2013 and newer
;;; Creates separate drawings of all layouts.
;;; The new drawings are saved to the current drawings path
;;; and overwrites existing drawings.
(defun c:LayoutsToDwgs (/ errexit undox olderr oldcmdecho fn path
msg msg2 fileprefix i j)
(defun errexit (s)
(princ "\nError: ")
(princ s)
(restore)
(defun undox ()
(command “._undo” “_E”)
(setvar “cmdecho” oldcmdecho)
(setq error olderr)
(princ)
(setq olderr error
restore undox
error errexit
(setq oldcmdecho (getvar “cmdecho”))
(setvar “cmdecho” 0)
(defun DelAllLayouts (Keeper / TabName)
(vlax-for Layout
(vla-get-Layouts
(vla-get-activedocument (vlax-get-acad-object))
(if
(and
(/= (setq TabName (strcase (vla-get-name layout))) “MODEL”)
(/= TabName (strcase Keeper))
(vla-delete layout)
(vl-load-com)
(setq msg “” msg2 “” i 0 j 0)
(command “._undo” “BE")
(setq fileprefix (getstring "Enter filename prefix: "))
(foreach lay (layoutlist)
(if (and (/= lay “Model”) (> (vla-get-count (vla-get-block (vla-Item (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))) lay))) 1))
(progn
(command "
.undo” “M")
(DelAllLayouts lay)
(setvar “tilemode” 1)
(command "
.ucs” “w")
(setvar “tilemode” 0)
(setq path (getvar “DWGPREFIX”))
(setq fn (strcat path fileprefix lay “.dwg”))
(if (findfile fn)
(progn
(command "
.-wblock” fn “Y")
(if (equal 1 (logand 1 (getvar “cmdactive”)))
(progn
(setq i (1+ i) msg (strcat msg “\n” fn))
(command “*”)
(setq j (1+ j) msg2 (strcat msg2 “\n” fn))
(progn
(command "
.-wblock” fn “*”)
(command “N")
(command "
.undo” “_B”)
(if (/= msg “”)
(progn
(if (= i 1)
(prompt “\nFollowing drawing was created:”)
(prompt “\nFollowing drawings were created:”)
(prompt msg)
(if (/= msg2 “”)
(progn
(if (= j 1)
(prompt “\nFollowing drawing was NOT created:”)
(prompt “\nFollowing drawings were NOT created:”)
(prompt msg2)
(textscr)
(restore)
(princ)
(princ)
Not a Dynamoscript but I’ve used the same LISP with no issues of having to click OK on anything.
I’ve sent you a DM.
Hi Henrik,
Could you send me the same LISP file.
bro u need the lisp Layout to dwg without any click
