the offset method is no longer valid?
I need to access the revitapi but some api only work on curve, not line.
do you need some libraries ? , i use in general the Primier frame:
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
Can you give us more information about the Offset issue? Why is it no longer valid? You’re showing it working.
You’re correct that the Revit API methods for Curves do not always work for Lines, however Revit Lines inherit their members from Curves, so that is not the issue. You are however attempting to use a Revit method on a Dynamo object without loading the Revit API. Do a little more digging through the forums but you’ll need to load the API before you can use it and you’ll also have to convert the Dynamo geometry to Revit geometry as well.
Could be my template is overloaded, but i think it works
clr.AddReference('RevitAPI')
clr.AddReference('System')
x = UnwrapElement(IN[0])
OUT = x.PointAtParameter(1)
hi, PointAtParameter is not from revitapi, so sure it works.
2 curves (1 + reverse) for a line if you are interested
But, it is necessary to read remark of Mr. C.Poupin of yesterday on Line and curve
(question from yesterday)
Cordially
christian.stan
Unwrapping is not the same as converting geometry. There are conversion methods or you can break down the Dynamo curve and rebuild it as a new Revit curve.
The method you’re using there is not from the Revit API. It’s a Dynamo method. I believe Dynamo now retains Lines as Lines when making conversions but either way, there’s no functional difference between a Line and a Curve. Why do you specifically need a Curve? Are you trying to convert the Line to a Curve so that you can use a Revit API method on the Curve? Which method are you trying to use?
