I’m having an issue with a scrip I’m working on. I have multiple sections of it that I freeze when I don’t want them to run. The script includes these groups that I freeze depending on what I want to do:
- Delete Line Patterns that don’t include “zz-”
- Append “zz-” to existing line patterns
- Add Line patterns from an excel sheet.
- Delete Line styles that contain certain strings
- Create lines styles using line patterns created above
- Create text notes with the line pattern name
- Create lines with line styles created above (not complete)
Number 7 is not complete because I noticed that line patterns generated by number 3 keep getting removed for some reason. This is my work flow.
Every group has certain input nodes freezing the rest of the group. I unfreeze 3 and run the script. Freeze 3. Unfreeze 5 and run the script. Freeze 5. At this point the line patterns and style are set up correctly. At this point I would unfreeze 6 and 7 to run that portion. After running them the line patterns are gone.
I’ve also tried this with 6 and 7 frozen. Same issue. Am I just using Dynamo incorrectly?
Revit Dev - Line Pattern Script V2.dyn (218.6 KB)
