Hi, I was wondering if U found a way to install libraries in Dynamo’s IronPython?
You should upgrade to cpython3
If you still want to pursue that, here is the suggested link for you
Yes it’s possible, but currently only pure Python libraries (without code dependency written in C ) are compatible more info and example here (use the Google Translation widget)
you can also use the CPython3 engine if you work on Revit 2022
