Length of list of point
In a code block i have :
polyCurve1 = PolyCurve.ByPoints(t1, false);
num1 = Autodesk.Curve.Length(polyCurve1);
t1 is a list of points
Point(X = 11.889, Y = 5.391, Z = 0.000),
Point(X = 11.889, Y = 5.391, Z = 2.750),
Point(X = 11.889, Y = 7.496, Z = 2.750),
Point(X = 9.633, Y = 7.496, Z = 2.750),
Point(X = 9.633, Y = 8.026, Z = 2.750),
Point(X = 9.103, Y = 8.026, Z = 2.750),
Point(X = 9.103, Y = 8.766, Z = 2.750),
Point(X = 9.103, Y = 9.296, Z = 2.750),
Point(X = 8.573, Y = 9.296, Z = 2.750),
Point(X = 3.785, Y = 9.296, Z = 2.750),
Point(X = 3.785, Y = 6.873, Z = 2.750),
Point(X = 3.785, Y = 6.873, Z = 0.333)
How can i translate this in Python ?
Daniel OLIVES
@daniel82KGE ,
thats the designscript solution
Point.ByCoordinates( 11.889, 5.391, 0.000),
Point.ByCoordinates( 11.889, 5.391, 2.750),
Point.ByCoordinates( 11.889, 7.496, 2.750),
Point.ByCoordinates( 9.633, 7.496, 2.750),
Point.ByCoordinates( 9.633, 8.026, 2.750),
Point.ByCoordinates( 9.103, 8.026, 2.750),
Point.ByCoordinates( 9.103, 8.766, 2.750),
Point.ByCoordinates( 9.103, 9.296, 2.750),
Point.ByCoordinates( 8.573, 9.296, 2.750),
Point.ByCoordinates( 3.785, 9.296, 2.750),
Point.ByCoordinates( 3.785, 6.873, 2.750),
Point.ByCoordinates( 3.785, 6.873, 0.333)
in python this way ?
clr.AddReference("ProtoGeometry")
x = IN[0]
y = IN[1]
z = IN[2]
pt = []
for xpt,ypt,zpt in zip(x,y,z):
	pt.append(Point.ByCoordinates(xpt,ypt,zpt))
OUT = pt;
KR
Andreas
Where does the length of the list come into play and why do you need it in Python? You’re using Dynamo geometry here, so you’d either have to mirror the same Dynamo functions in Python for a Dynamo object or replicate this workflow with a PolyLine if using the Revit API. We need more information.
@daniel82KGE ,
at least i got a nurbscurve… polycurve needs some kind of sorting
x = IN[0]
y = IN[1]
z = IN[2]
pt = []
pt.sort()
polycurves = NurbsCurve.ByPoints(pt,True)
OUT = polycurves
KR
Andreas
hello, I don’t know how to create Ilist
in the Polyline class at the property level there is no reference to length
Transforming to polycurve dynamo (poly.ToProtoType()) doesn’t work for me
I don’t know if this will help
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
def dyn_rev_mtofeet(a):
    revPoint=XYZ(1/0.3048*a.X,1/0.3048*a.Y,1/0.3048*a.Z)
    return revPoint
list_point_revit=[dyn_rev_mtofeet(i) for i in IN[0][0]]
poly=PolyLine.Create(list_point_revit)
nb=poly.NumberOfCoordinates
OUT = poly,nb,type(list_point_revit)
Cordially
christian.stan
PolyCurve needs Revit Points so i convert my Xyz list in ToPoint()
And now i have my length
Daniel OLIVES
