How to get curves from surface in python
Hi All,
After exploding my solid geometry I get surfaces, and I want to get curves from these surfaces, so what’s wrong in my code below?
import sys
import math
from Revit.Elements import *
[Shaft_Geo] = Element.Geometry(IN[0])
Shaft_Surfaces = Geometry.Explode(Shaft_Geo)
OUT = Surface.PerimeterCurves([Shaft_Surfaces])
Thanks.
The error tells you that the method expects a Surface but was given a List. In the last line you wrap Shaft_Surfaces in a list. That’s causing you problems. Just pass the surface as-is.
here is
import sys
from Revit.Elements import*
geo=Element.Geometry(IN[0])
surf=Geometry.Explode(geo[0])
curv=[Surface.PerimeterCurves(s) for s in surf]
OUT = geo,surf,curv
Cordially
christian.stan
@Nick_Boyts @christian.stan
This is an never ending Shaft :grin:
I got all my curves listed as shown below:
Now I want to get the length of each curve and keep the structure of my main list and the nested sublists, but I get the error message below
What’s wrong in my code here?
import sys
import math
Geo = Element.Geometry(IN[0])
Surf = Geometry.Explode(Geo[0])
Curvs = [Surface.PerimeterCurves(i) for i in Surf]
for i in Curvs:
    for j in i:
        Curv_length = [Curve.Length(j)]
OUT = Curv_length
Thanks.
Hello, here,
You forgot a container
It must have been faster for sure.
import sys
#You need an empty container to store your loop result
length_c=[]
temp=[]
for level_list in range(0,len(curv)):
    for c in curv[level_list]:
        temp.append(c.Length)
    length_c.append(temp)
    temp=[]
OUT = geo,surf,curv,length_c
edit: Don’t take this as a presumptuous message from me :wink:
check out this very informative post
Clear and instructive instruction
I love women, don’t worry Mr. Sol Amour :wink:
Cordially
christian.stan
@christian.stan
Thanks Christian
Can you rewrite the whole code in a single line using enumerate or zip function? (just for another option)
    temp=[]
Thanks.
