at which node I should use lacing so whole script will run again & again with new value every time.
I’m trying to iterate this script.
REVIT.rvt (5.3 MB)
Export.dyn (51.5 KB)
123.xlsx (11.8 KB)
Doesn’t appear to be a lacing issue. What are you changing between runs?
@jacob.small
Next value from the list
List Levels would be easier.
Hi, As per my understanding you are trying to export each duct type with a different system abbreviation into CAD. As a first step I would suggest creating views for the same. The attached script can generate views like this for each different system abbreviation which can then be used to export to dwg. The dwg export can also be integrated into the graph but has been kept out of it for simplicity.
Export-SG-A.dyn (49.9 KB)
