Labeling Input Output
When I try to give a label to the Input/Output nodes in a Custom Nodes Dynamo starts adding “var…” in a random fashion. I end up having very long label sometime.
What is the best way to give labels to a Custom Nodes?
Is it possible to give default values?
here is an example of the problem I get:
forum_dynamo
Hi @Askbid,
// is meant to comment in designscript but doesn’t define your input.
Add a line with a name for your input like this:
custom%20node
here are some rules:
don’t use spaces
// are for comments
this should be the same code you use in a codeblock when you declare a new variable. If you don’t explicitly add a type we’ll default to var… - arbitrary rank array (nested lists of any rank - will not replicate)
is there also a way to give a default value for numerical values?
For example :
Number : int=0
or
Number : double=0
