Label Geometry
I’d like to know if it’s possible to retrieve the geometry (specifically the rectangular boundary) that encloses the labels of pipes and structures in Civil 3D using Dynamo.
Hi @Diogo.Azevedo,
Try the Object.Extents node and see if that gets you what you need.
Hi @zachri.jensen, using the Extents node I got the bounding box, but it’s not the same as the label’s border box.
model view:
OK, understood. There isn’t an easy way to get that border without exploding everything down.
I’m curious though, what are you ultimately trying to achieve in your workflow?
I’m trying to check if there is any interference between labels geometry.
Labels against labels, or labels against everything?
Does Object.Geometry work?
You can copy them, explode, get the geometry and then delete the copies.
Did it to get the geometry once and it did work out really well (it was on the 2023 version, but I don’t see why it wouldn’t work now).
Not ideal, of course, but it works…
No
Can you post a sample drawing for review? It’s a long shot but I have an idea I can try in the morning if I have a dataset and a C3D version.
Unfortunately, there’s no way to copy a label. So I had to open the same DWG file in read-only mode (for safety), explode the labels, and that way I was able to get the geometry I needed.
The “extend” node captures everything from the location point of the pipe/structure to the rectangle that surrounds the text, which makes the resulting bounding box larger than it actually is.
@apegaia thanks for the sugestion.
Just checked here, you’re absolutely right. You can copy labels on the 2023 version of the Object.Copy node, but not on the 2025 one…
Since I didn’t want to open another drawing just to explode the labels, I ended up creating this small Python script to clone the labels and extract their geometry, which I’m using for label overlap detection.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
lables_list = IN[0]
editor = adoc.Editor
handles = []
with adoc.LockDocument():
    db = adoc.Database
        # Espaço atual do modelo/layout
        btr = t.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
        for label in lables_list:  # Lista de labels
            try:
                original = t.GetObject(label.InternalObjectId, OpenMode.ForRead)
                clone = original.Clone()
                btr.AppendEntity(clone)
                t.AddNewlyCreatedDBObject(clone, True)
                # Obter handle da label clonada
                handles.append(clone.Handle.ToString())
            except:
                handles.append(None)  # Em caso de erro
        t.Commit()
OUT = handles
Awesome approach! Hadn’t thought about that!
Also, I believe there’s now a node to get the object handle directly (don’t remember if it used to exist before)
With all the interactions, I was able to create a Dynamo script to solve a common issue in large-scale Civil 3D drawings: the manual and error-prone task of reviewing labels one by one.
Previously, verifying whether each structure and pipe was correctly labeled — and checking for overlaps or duplicates — was a slow and repetitive process.
:red_circle: Detect overlapping or duplicate labels
:orange_circle: Identify pipes or structures with no label
:yellow_circle: Flag elements with multiple labels
That is an excessive amount of labels :smiley:
Great work!!
Hi Diogo,
Great work! By any chance you can share the script? Thanks!!
