I don’t understand why my code(python) for keySchedule in Archilab leave a row at the beginning when it appended to revit. I attached 1 picture of the table I get the data from excel. The grey mark on the code I put in, so it delete the table every time it is updated.
Do you have your schedule appearance setting set to show blank row before data?
No, I don’t set it to show blank row. That row actually is an extra line from the table for whatever reason it is.
Is it because your range starts at 1 and not 0?
No, when I change it to 0 for the part I marked grey. The table doesn’t show up. And that part isn’t what causing the problem. Even if I delete the part I added in and delete the table manually before running the code. the blank row still show up. I think it has to do with getting the numbers of line from the tables, but I wasn’t sure, because I could tested manually like create “print” in C.
