Key Schedule generates empty schedule
Hi there,
Hi @Konrad_K_Sobon
I have a graph using Archilab’s Key Schedule Node
In Revit 2020 this works fine,
I recreated the Graph in Revit 2023, but I only get (the right number of) empty lines.
How Can I adress this?
Kind regards,
Willem
Key Schedule vanuit Dynamo BXL Zuid herbegonnen 2023.dyn (16.3 KB)
Owkay, according to my AI friend, there was an issue trying to decode a string in Line 68
Follow
Copyright(c) 2015, Konrad Sobon
@arch_laboratory, http://archi-lab.net
import sys
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
Import ToDSType(bool) extension method
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
import re
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
keySchedule = UnwrapElement(IN[0])
data = IN[1]
inputParams = IN[2]
upper = IN[3]
“Start” the transaction
tableData = keySchedule.GetTableData()
sectionData = tableData.GetSectionData(SectionType.Body)
keyNames =
for i in range(1, sectionData.NumberOfRows - 1, 1):
keyNames.append(str(int(i)))
allKeys = FilteredElementCollector(doc).WhereElementIsNotElementType()
params = [ for i in range(len(keyNames))]
test =
for key in allKeys:
try:
if key.get_Parameter(BuiltInParameter.REF_TABLE_ELEM_NAME).AsString() in keyNames and key.OwnerViewId == keySchedule.Id:
indexValue = keyNames.index(key.get_Parameter(BuiltInParameter.REF_TABLE_ELEM_NAME).AsString())
for i in range(0, len(inputParams), 1):
params[indexValue].extend(key.GetParameters(str(inputParams[i])))
except:
pass
for i, j in zip(params, data):
for param, value in zip(i, j):
if isinstance(value, str):
valueDecoded = value
if value is None:
valueDecoded = " "
valueDecoded = str(value)
if upper:
valueDecoded = valueDecoded.upper()
param.Set(valueDecoded)
“End” the transaction
#Assign your output to the OUT variable
OUT = keySchedule
Was there ever a solution to the blank schedule output?
Hi @JCJPG
yes, please find it here!
Key Schedule vanuit Dynamo 04.dyn (27.8 KB)
Keep in mind that you have to make the key schedules with expected parameters for a room first…Might be the purpose of another script.
Kind regards,
Willem
Thank you so much!
