Key Schedule data import not importing boolean
I’m using the archilab key schedule node to import data into key schedules. The boolean (yes/no) is not working, they only turn up as grey in the key schedule. I have tried replacing the true false with 0 and 1 as well. String and number data imports fine.
Hi @daninet I think it’s normal behavior also when we add a yes no parameter manually without setting a value.,but you could get these keys elements after and set a value..think something here
Revit_Gy7tMBQlwS
Hi sovi,
May I know what’s in the python?
Thank you,
Yeah sure, my bad forgot attach…try here
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FilteredElementCollector
key = UnwrapElement(IN[0])
OUT = (
    FilteredElementCollector(doc,key.Id).ToElements()
    if hasattr(key, "KeyScheduleParameterName")
    else "it isnt a keyschedule!!"
