KeySchedule & Integer Values
Hi All,
Quick qs is it possible to add integer values to a key schedule or am i missing something,all other elements get set however i cant get the integer values applied.
image (01) excel
image (02) Revit populated schedule
image(03) Dynamo screen shot
Cheers Ks
The archilab node converts all incoming values to strings, therefore the element parameter will not update due to the type mismatch with integer
Thanks @Mike.Buttery Do you happen to know of another way or node that could be used to work around that?
Cheers KS
I don’t think there is - you could modify the archilab node python
Crack open the node and update from line 53 to before # "End" the transaction in the second python node
I’ve also done a bit of refactoring so it does not check every element in the document, just the schedule
allKeys = FilteredElementCollector(doc, keySchedule.Id).WhereElementIsNotElementType()
params = [[] for i in range(len(keyNames))]
test = []
for key in allKeys:
	try:
        keyName = key.get_Parameter(BuiltInParameter.REF_TABLE_ELEM_NAME).AsString()
		if keyName in keyNames:
			indexValue = keyNames.index(keyName)
			for i in range(0, len(inputParams),1):
				params[indexValue].extend(key.GetParameters(str(inputParams[i])))
	except:
		pass
for i, j in zip(params, data):
	for param, value in zip(i,j):
		if isinstance(value, str):
			valueDecoded = value.decode('string_escape')
        elif isinstance(value, int):
			if value == None:
				valueDecoded = " "
				valueDecoded = str(value).decode('string_escape')
		if upper:
			valueDecoded = valueDecoded.upper()
			param.Set(valueDecoded)
Thanks @Mike.Buttery I believe I copied it across correctly but outcome was still the same.
I’m using Revit 23 could that be the issue?
Cheers KS
The code doesn’t look like it’s updated there should be an elif at line 69 and the filtered element collector should only be for the schedule view like this FilteredElementCollector(doc, keySchedule.Id) on line 53
Make sure to save the script after updating, then save the custom node and finally try your graph
Hi @Mike.Buttery apologies I updated below and get the following warning.
Thanks again for your time.
Cheers KS
Mixed tabs and spaces unfortunately - find and replace tabs with 4 spaces
I’m looking into how to update integers as my code change does not currently work
All numbers from an excel sheet are considered Double / float even if they are integers
Change
To this
elif isinstance(value, (int, float)):
    valueDecoded = int(value)
Note this is for your use case
You would have to check the parameter storage type is ‘Integer’ and then check if all data values are integers and convert (or just convert them with int(n))
Awesome thank you @Mike.Buttery this works.
Was trying to paste updated code for future reference , how do i make it look like this
image instead of this
Cheers KS
Use the </> code option in menu, surround by single backticks (under esc key) or surround by triple backticks for a block. If you include the code language after the first triple backticks you get syntax highlighting
```python
<code>
Thanks updated code below based of your first response from line 53 to before # "End" the transaction in the second python node.
Thanks again for the help.
Cheers KS
`<allKeys = FilteredElementCollector(doc, keySchedule.Id).WhereElementIsNotElementType()
test = []
for key in allKeys:
    try:
    except:
        pass
            if value == None:
                valueDecoded = " "
        if upper:
            param.Set(valueDecoded)>`
