K-Family Insert Node does not work
i made solids and i want to make famiy(familytype)
but K-Family Insert does not work. My K-Family Insert Node export Value as Null all…
My Revit Version is 2022.1 and I’m Using Dynamo 2.12 and Package Version is 12.7.5
And I also test as DirectShape and it works
but I want Family that i can edit…
Please Help me
Pls did you fix this?I had the same problem as you
Hello @wulinfengjiang and welcome…does it work if you disconnect the filepath and categori ? guess the default setting in that node is a generic template and categori generic…if you right click in the node input you will see it set to default
