Joining Lines from X Y points
Hi Guys, If you notice in the flatten node, the node have Line Start with X&Y coordinates, any idea how Can I combine them and make them as one model line ?
@ahmadkhalaf7892 ,
for joining lines you need the workflow first item/rest item
Hi Andreas, I appreciate the help, I am trying to draw walls on this curve , but the thing is the polycurve is not working with this node , can I change it again to a single curve or what should I do exactly , again thanks a lot
Hello
You can send a list of curves in the node too
Cordially
christian.stan
Hi christian , I didn’t get exactly what do you mean
Thanks for the help
Like this
Cordially
christian.stan
Thanks christian , I’ll see what Can I do since I am getting the points from the alignment
There is this one :wink:
Cordially
christian.stan
