I have a mass with individual surface.
I want to join them together and apply Lunchbox Quad Grid by Face.
But the outcome of grid lines are divided by each surface, not one large surface.
It means I only join them in the one group of list, but that are still individual surface.
you could try to make a little void inside the geometry to get rid of the seams
Try to create a Nurbs curve through tightly spaced points along the top and bottom surface’s perimeter curves, and then loft those to generate a single surface. Making a polycurve and lofting may also work but I’m not certain.
Thank you for all replies.
I used to draw a Nurbs curve or original profile curve in my Mass model.
It is sad that we need to re-draw the curve to get a smooth surface.
@FreddyY this is pretty common. You would have the same issue in Grasshopper for example. UV subdivision only works on surfaces, not polysurfaces.
I still have long way to learn Dynamo.
