I have different rectangular surfaces which have spaces between them due to walls. I want to join all these surfaces into a single surface. Can anyone suggest me node or method? Thank you in advance the screenshot is attached
They don’t touch, so how can they be one surface?
Why do you want them to be one surface while still having gaps dues to walls ? Extracting any information, or applying any action to those surfaces does not require them to be joined. It just requires them to have a shared parameter which can be extracted.
then how can I do meshing on the whole surface? any idea? because the delaunay.ByparameterOnSurface is not working in different surfaces.
You could try the following:
- Extract the perimeter of the surfaces and join them in a polycurve
- Offset the polycurve outwards sufficiently enough to overlap the adjacent floors (e.g. if the usual wall thickness is 250mm, then offset all the PC by 200?)
- Rebuild the surfaces
- Thicken the surfaces
- Union them in a solid
- Slice the solid with a plane to get a unified surface
@Dimitar_Venkov’s solution might work, but what is it you’re after in the end? Offsetting May cause May cause other issues.
If your surfaces are defined by the room boundaries, how about including the wall geometry itself in the union mentioned by @Dimitar_Venkov ? List all the walls you want and use Element.Geometry to get the solids and union them with the rest then slice the whole thing and join the resulting surfaces with Polysurface.ByJoinedSurfaces. That way you can also define whether you want to include or exclude exterior walls in your area.
And speaking of Areas… wouldn’t you be better off drawing a boundary and using an area to get your mesh ? That’s probably going to get a cleaner result.
Hi, may I ask whether the problem been solved or not? I have the same problem.
Thank you.
Hi Dimitar,
I tried your approach on my model, every step seems to work well but the Delaunay node still shows empty list. Could you please tell me is there anything wrong in my code? Thank you very much (69.4 KB)
