Hi all, I’m having issues smoothing out a surface.
I’ve selected a face of a mass in RVT, I then used the offset node and now want to join these two surfaces organically. I managed to split the edges to create two points which can be joined with a 2 point arc. It seems like I get the essence of the idea but not aesthetically and technically what I’m looking for.
I now have issues joining the sides with the top and bottom seamlessly.
Is there any suggested mesh smooth workflows?
Should I revert back to the drawing board and see if I can create a sweep with and profile that connects the two surfaces? Is this possible?
I know its possible in the massing environment, but I would like to solve this in Dynamo.
Any suggestions will be greatly appreciated.
KM
See RVT base file and WIP Script below:
Dynamic Shape test_03.dyn (116.9 KB)
SurfaceMass.rvt (696 KB)
