I am attempting to make a dynamo script that can modify selected (itm) hangers and then adjust length of rod in a model. Does anyone have any ideas or advice? I am pretty sure that I will need a python script for modifying an itm in revit but am pretty useless at python?
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
toList = lambda x : x if hasattr(x, "__iter__") and not isinstance(x, (str, System.String)) else [x]
lstelems = toList(UnwrapElement(IN[0]))
length_rod = IN[1] * 3.28084 # convert meter to feet
for elem_part in lstelems:
rod_info = elem_part.GetRodInfo()
rod_info.CanRodsBeHosted = False
rod_info.SetRodLength(0, length_rod)
new_rod_lenght = rod_info.GetRodLength(0) * 0.3048
OUT = lstelems , new_rod_lenght
Thats amazing. You made more progress in a few days than I have in a few weeks. The only step left would be to adapt the code to work on our libraries correct? Or am I misunderstanding something?
You don’t have an object at that point. The instance which you are asking to “GetRodInfo” from doesn’t exist.
Context is a must for debugging. What is line 34 in your code? Assuming it’s the same as Cyril posted it is possible that you have provided a “null” or “empty list” into the Python node. Clear those out.
Can you confirm what inputs you have coming into IN[0] of the python node? My gut tells me you have something other than a hanger selected at some point, but we need the larger context leading into the Python node to confirm.
You haven’t selected hangers with the select model elements nodes.
Hit the button that says ‘select’ on the first Select Model Element node and pick a hanger. Then do so again for the second. Then run the graph again and see if the Python gives a better result.
The issue there is when I hit select absolutely nothing happens in dynamo or revit. For some reason the select button doesn’t seem to do anything. It seems to be “greyed out“.
If I click on select and then click an element nothing loads. The select button appears to be dead. I don’t know why it wont let me select an element? I’ve never had this issue before.
