Hi all!
I’m a beginner in Python. Can somebody help me, please?
I have a list of families and a list of parameters, the scope is to create for each family a group of parameters. For the family at index [0] to create parameters at index [0] from the parameter list.
I suppose that the Iterative Loop Statement starting at row 32 need some adjustments.
# Enable Python support and load DesignScript library
clr.AddReference("RevitAPI")
par_name = IN[0]
exec("par_type = ParameterType.%s" % IN[1])
exec("par_grp = BuiltInParameterGroup.%s" % IN[2])
inst_or_typ = IN[3]
families = UnwrapElement(IN[4])
# class for overwriting loaded families in the project
class FamOpt1(IFamilyLoadOptions):
def __init__(self): pass
def OnFamilyFound(self,familyInUse, overwriteParameterValues): return True
def OnSharedFamilyFound(self,familyInUse, source, overwriteParameterValues): return True
trans1 = TransactionManager.Instance
trans1.ForceCloseTransaction() #just to make sure everything is closed down
# Dynamo's transaction handling is pretty poor for
# multiple documents, so we'll need to force close
# every single transaction we open
result = []
for f1 in families:
famdoc = doc.EditFamily(f1)
try: # this might fail if the parameter exists or for some other reason
trans1.EnsureInTransaction(famdoc)
for j in par_name:
famdoc.FamilyManager.AddParameter(j, par_grp, par_type, inst_or_typ)
famdoc.LoadFamily(doc, FamOpt1())
result.append(True)
except: #you might want to import traceback for a more detailed error report
result.append(False)
famdoc.Close(False)
OUT = result
