Help!!! I am doing Swing Project referred from https://www.youtube.com/watch?v=_dSovbQtkAo. When it comes to the last step of rotation like image shown, I want to rotate all items in blue nodes in “Flatten”. However, when in “Geometry Rotate” Nodes, only two lines are validate. The project is complex, so I attach it. Could someone please help me fix it and tell me the reason? Sorry but I need it immediately. Thank you! The file is below named 507!
Hi Yebin,
i took a quick look at your script and I am pretty sure that you have a list structure/lacing issue.
What you feed your geometry.rotate note is :
multiple curves
2 base planes
1 angle
since the two base planes have the same normal, I don’t really see the poit of using two
then switching the geometry.rotate node’s lacing to longest should be enough
Thank you MOSTAFA! You help me a lot!
