Hi all,
I have two lists to process in a Geometry.DistanceTo node.
First list contains two lists, first of 16 items, the second 3.
Second list contains 2 items, 4 items each.
I need the result to be same structure as first list, that is 16 items plus 3…
I tried all levels and lacing, I just cannot get it.
The closest I got is in the screenshot, where everything seems okay, except the first list is truncated at 4 items, instead of 16…
Basically, every item in the first list is some geometry of elements (listed by view and then by elements, thus the two level list), and the second list has the boundaries of view-ports (two lists of 4 lines each).
I need a list with the same structure as the geometry by view (first list), with the distance values…
I have setup lacing and levels for many scripts, and I have always found the combination I needed, but not this time…
thank you
regards
