I am running into some strange issue with Refinery Packing.PackRecatnagles. The packing method does not seem to recognize the different rotations of the containers…?!!
Rotated packages cause it issues - I have an animation somewhere showing how the resulting packing goes further off the rails as soon as you surpass a few angles, mirror the container, or otherwise alter the base geometry.
I recommend getting the primary axis of the container and rotating it to the X or Y global axis, running the packing algorithm on the oriented rectangle, and then rotating the packed objects back into the correct location. Coordinate systems may also be more effective than rotation, to allow for resolution of mirrored containers as well.
Thanks @jacob.small for your explanation… so that is very tricky…! But at least now I can try to explore your suggested solution.
… if by any chance you find the animation then please share link to it when you can.
Thanks @jacob.small - this is very useful info. I truly wonder if the GD development team will look into this issue to overcome such limitation. The pack rectangles routine node is very helpful in many application.
Thanks again for your help.
