hello Guys i have a problem : i’m doing a dynamo graph to run a generative design study on space distribution in revit trough refinery, but after i select the room from revit and after i do the bounding box to allow the creation of a container to give as input for the package of the design options inside the room in the packing.packrectangles node , it doens t take into consideration the columns, so that the spaces that i have to put inside the room overlapses with columns… but i would like the generative design study to understand that the columns shoun t be part of the generative design surface… is there anyone that can help and suggest a strategy to solve this? i attch the screen of the nodes where you can see the solid that doesn t take into consideration the pilaster but then when i convert as rectangle to give it as input in packing it unificates everything into one single rectangle…
Related topics
| Help! Revit Generative Design doesn't display any geometry | 2 | 235 | June 14, 2023 | |
| Generative design study keeps running | 14 | 490 | April 6, 2024 | |
| Generative Design with Dynamo shows wrong results | 10 | 1073 | January 14, 2021 | |
| Generative design study not giving outputs and geometry | 0 | 56 | December 3, 2024 | |
Generative design layout / space planning automation
10 | 2031 | January 5, 2022 |
