Issue with UI.ListView Data
Good Day,
@Mostafa_El_Ayoubi
I am trying to input two parameters(Numbers and Names) into Tool.CreateEmptySheet using UI.MultipleInputForm. Please refer image below and advise on my issue. My task is to input a value fro number of sheets and select a family with a dropdown menu.
GenerateBlankDrawingSheets_v3.dyn (37.4 KB)
Hi @jwy997 ,
Take a look at this blog post : https://data-shapes.io/2016/12/13/ui-multipleinputform/
It’s not all up to date but it’ll definitely help you!
Also, there’s a primer documenting each node of the package and how to use it :
https://datashapes.gitbook.io/primer/ui/listview-data
