When including the default indices in the UI.Listview Data node I cannot get the UIMultipleInputForm++ to open it errors out. Error in the form shows index out of range and is always 5 numbers off of the number of keys / values (even if i change the amount). Has anyone else run into this issue? Is the format of my inputs correct?
Currently can’t post an image but will keep trying…
Dan
That works for me as well, some more information the image would help… I am using List.AllIndicesOf to generate a list of all trues (or checked). Can i push that list into the default values? Seems i need to reformat it first?
What does your list of Keys look like?
hi @dcesarz ,
Please share a screenshot
I’m sure this is a formatting thing, sorry for the newb question…
there are 998 keys and only 691 indices as well…
Two questions :
-how many elements are in your “keys” list
-what version of the package are you using?
Oh wow that’s an old version! Could you please udpate to the latest version and see if it still behaves the same?
!WARNING! : In case you have many script using Data Shapes, you’re going to have to activate default values on new inputs
Hey @Mostafa_El_Ayoubi - still unfortunately having the same issue.
I’m having a hard time reproducing the error. Can yo share your data set?
no problem, here it is, thanks for looking into it!
Test Family_ALL Project Setup.dyn (33.7 KB)
Starter_IDS Families Master.xlsx (48.6 KB)
anyone have any thoughts on this?
@Mostafa_El_Ayoubi - just curious if you found anything that i should modify with my dyn to get it to work?
