In the last two weeks I had an issue with Dynamo: i couldn’t update it. I tried downloading the new version 2.0.0 from the site and installing it. I encountered some problem and I found out through some question of other users that the majority of installation issue are caused by a conflict with older versions of Dynamo. I unistalled my version (1.3.2) and I retried the installation but I still had the same problem. I then tried to reinstall the older version both 1.3.2 and 1.3.3 and the issue was now diffused on the other installations too.
When I try to install any Dynamo version the program correctly extract the .msi files in a temp folder but then when the real installation starts it stops itself while installing and a window pop-up both when it tries installing DynamoCore.msi and DynamoRevit.msi
[https://i.imgur.com/eluw5Bu.jpg]
[https://i.imgur.com/pretrJk.jpg]
The text in the windows are a list of comand prompt for Windows installer:
Windows ® Installer. V 5.0.16299.15
msiexec /Option [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t ] [/g ]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*]
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log
Equivalent of /l*
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall [;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
From what I could see on the internet the problem could be either caused by a missing link or by a Windows problem
I tried some solutions (like the register/unregister commands in the prompt) but it seems nothing is working.
The funny thing is that if I open the temporary folder of the installation and I run the .msi by themselves they work fine. The problem is that it is not a solution being that while I can install Dynamo Core just fine the DynamoRevit.msi cannot be run by itself
I’m running Windows 10 and I have Revit 2018
