Isolate in View
a question about the ‘Isolate in View’ node by Archilab.
When i use multiple elements as input the node works. But when i use one element as input the node does not work.
I want to isolate 1 element per view. What should i do?
EDIT: same is happening for other nodes. Also with
-Element.TemporarilyIsolateInView
-Element.PermanentlyIsolateInView
So the problem does not seem to be with the archilab node. More it looks like its about the ‘Select model element’ node.
For example: With the Element.TemporarilyIsolateInView, the ‘temporary isolate mode’ is activated in Revit. But no elements are isolated.
Try adding a ‘List.Create’ node after your single item selection. Does that work? They way Python interacts with items is important - and most require them to be lists to do any form of looping.
That’s it. Thank you very much.
