I’d like to get some faces information in complex surface. When I used Edge.AdjacentFaces node to get the faces from the edge, I received a warning message “Warning: Edge.get_adjacentFaces operation failed. The method or operation is not implemented.”
Can’t I use Edge.AdjacentFaces node in Dynamo 0.8.2? I received same warning message by Vertex.AdjacentFaces node.
I attached the simple graph. I’m using Dynamo 0.8.2
Are there any misunderstand?
Thanks,
makoo
