Hey Guys
I am running Dynamo 0.9.1. I am trying to find the Mesh.FaceVertices command. I am following an example of turning a mesh into a polysurface. Not sure if this command has been replaced, in another package or omitted in the current version that I am using.
Thank you in advance.
Fenn
Hi Fennen
here is an example I made in 0.9.1 with ootb nodes
Hi Mostafa
That’s perfect. Thank you very much.
Kind regards,
Fennen
Have a look inside the Topography.ToPolysurface node from the spring nodes packages to see a quite speedy conversion from topos:
Just make a mesh your input instead.
Thanks Jostein
I’ll give your method a go too. You guys are brilliant. Just been using Dynamo for a few dynamo for a few days now.
Regards,
Fennen
