Is there a way to delay to go to the next node untill finish command
Is there a way to delay to go to the next node untill finish command in command line I use passthrough but the command finish after passthrough
because the nodes after the command depend on data from command
use a “gate” by using
[input,waitfor][0]
in a codeblock
I use it but the drawing import (from command line) after this
is there a way to add time in second to go to the next node
You could try the time in python:
import time
time.sleep(IN[0])
OUT = True
