Is there a way to check use targets on the same side as the subassembly for Corridor
Is there way to check use targets on the same side as the subassembly for Corridor
Hello fellow scripters,
Can anyone give an update as to whether the above is available now with dynamo, or. Net api?
I am working on junction automation and most functionality seems to be OK apart from having to manually go through multiple junctions and turn off the above check box to get the targeting to work properly.
Any feedback now in mid 2024 would be great.
Regards,
cjm
Have you checked the API documentation for 2025? If it isn’t there then it is safe to say it doesn’t exist yet, and your best bet will be to raise a feature request.
A breadcrumb for adding an offet assembly: Help
It has been added to the API in the latest 2024.4 update.
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-E032EFF9-8D28-4E72-867A-A6558CC8E7B7
Thankyou for Thanks for the feedback,
Any tips for how to get this to work using python? Anyone
cjm reply
