Is that possible to filter hatch pattern according to room NAME?
I’d imagine an == node and a FilterByBoolMask approach would get you close to what you’re after?
Hi @vikas.kpoojary try group curves from archilab for grouping these loops
EDIt sorry think i misunderstood …I guess you are after something here…but not 100
Revit_tM2pxmV5EQ
hey if you don’t mind can you share that file to me…
Yes sure…but first in a couple of hour as im in some meeting now without Dynamo :wink: edit …here it is but just remember its an exemple
Forum.dyn (56.8 KB)
sure, Thank you👍
its working but, my hatch is pre-defined already
is that possible ?
Hi its actuelly easier just create them in same run as i try to show…but offcoarse its possible that way, but you still need pair them up both with room number and name…just kitchen is not unique
i tried but its not happening, i think the curves should should be splited according to the room name then we can assign hatch
can you show where it doesnt work ?
Thankyouđź’• i filltered like this
r
