I am trying to extend an existing beam using Dynamo because I need to fill the space created by an opening. However, the beam is not extending to the desired length and is automatically attaching to a nearby beam. Is there a solution?
try this, if you want to do it in dynamo, try with below code or script
clr.AddReference('RevitAPI')
#Unwrapping Dynamo element to Revit element.
beams = UnwrapElement(IN[0])
#Disallow beam end joins in a transaction.
for beam in beams:
StructuralFramingUtils.DisallowJoinAtEnd(beam,0)
StructuralFramingUtils.DisallowJoinAtEnd(beam,1)
OUT = 0
Disallow Join at Beam Ends.dyn (62.5 KB)
