Good morning.
I have the need to disallow joining in the beams that I am creating, but when using the “StructuralFraming.DisallowJoins” node it seems not to work and I don’t know why that is… apart from that, a message appears in revit mentioning that it is not It is possible to keep the elements together between a beam and columns, but I never asked them to be joined?? Why does he return that to me?
Any other node or code in python that can give me a solution?
did you alos check the lacing ? f.e. set to XXX cross product or longest.
Hi, can you use the Transaction End node after the List.Flatten node?
Here is a really old Python code that has worked for me in the past.
clr.AddReference('RevitAPI')
#Unwrapping Dynamo element to Revit element.
beams = UnwrapElement(IN[0])
#Disallow beam end joins in a transaction.
for beam in beams:
StructuralFramingUtils.DisallowJoinAtEnd(beam,0)
StructuralFramingUtils.DisallowJoinAtEnd(beam,1)
OUT = 0
Disallow Join at Beam Ends.dyn (59.9 KB)
Hello @AM3D.BIM.STUDIO ,
When you click on Extensions → Workspace References, do you see any missing package warning?
You may need to install DynamoIronPython 2.7 to make the package node called StructuralFraming.DisallowsJoins work.
