Invalid literal for float dynamo to revit
Hey,
I have been trying to run Sun path on ladybug but to finish it because of the error (Image attached below). I searched in forums but unable to find a fix for this.
Looks like another user has run into this issue as well, see this GitHub issue. Chris Mackey (Ladybug co-founder) recommends exporting your geometry from Revit and doing the analysis in Rhino/Grasshopper instead.
That can be done. But would that be an issue in terms of creating a BIM Model …
Hi @puru0007
Did you have any luck with this issue, im going trought the same problem
I started using Rhino and grasshopper, it works over there.
