Does anyone know a way to get rid of the internal edges of this flat surface?
I allready tried to rebuild the closed curve from the end points but it makes no difference.
are you sure, is it flat ?
what does the Z.Values say ?
you could override the Z.Values with “0.0”
KR
Andreas
all the Z values are 0.000
from autocad Polylines
Link DWG, but i don’t think the problem is in the DWG. I used flatten on the faulty lines and it does not maken any difference. Also the other surfaces are from the same drawing
do you think it is in the DWG? if i create a floor from the lines and then get the top surface of that floor it gives the same result.
How can i tell you something wthout initial dwg data?
Maybe it’s different Z values of line’s vertices.
DWG faulty surface.dwg (784.5 KB)
i gave the faulty polyline a solid hatch, the others are translated correctly
getting it trough the hatch solves the issue. thanks a lot.
