I try to automate the integration of the ies file to a family typ. You can select the file with a button and after that, the ies file is “baked” into to Revit family (picture 1)
Although my script can write the path in the parameter to this file, then the file is linked only to the family, not integrated (baked). However, the lighting family should be passed on to customers and therefore no path may be in the parameter. The ies file has to be baked into the family.
@erfajo → Thx for your great package!
So its possible in Revit. How i can do it with Dynamo? The files are only examples. In real life there are a lot more ies files, i need to integrate.
Forum_set_path.dyn (13.3 KB) test.rfa (688 KB)
Can’t upload ies files…but every Revit user has his own:C:\ProgramData\Autodesk\RVT 2018\IES
The script works right at first glance. But the path is just a link. If you delete those files outside of Revit, then the family will not work either. But you can integrate the ies file exactly this way into the family. For this you have to press the button with the three dots and manually select the ies file.
Thanks for your help and sorry for my bad description.
But i don’t think your script works. The old ies file still seems to be stored in the parameter.
You can see this better on several types and ies files.
1.Now i try to set more than one ies file to a family type:
The script works. No error appears, but no ies file is assigned.
2. Only the first ies file was set as text on all types. But in the background here is no new ies file assigned. test_3types.rfa (632 KB) Forum_set_path.dyn (19.7 KB)
I uploaded your changed(little) graph and the family with 3 types.
Could you pls test it, with these files? The error appears when there are more than 1 ies file and 1 typ.
I’m sorry, I can not see the difference between your and my steps. The graphs and the test data are the same. I also tested it with Revit 2019. No difference.
I’ve tested the script and data 100 times in the last few hours. I really do not want others to do my job …
Things are getting a bit off topic, and boardering on personal attacks here so I’m closing this for a bit so the moderators can get a handle on the situation.
Yes i forgot about the list leveling.
Now are the names set correct…but in the background the ies files are not set.
You need to look at the “light geometry”.
The light geometry of WPE1MH.ies looks realy different:
But after the graph runs …nothing except the “names” changed
Following up on this, in case you want to know what was going wrong:
Fiesta, you are correct: It was NOT working, in the earlier Suggestions. But it wasn’t actually a Dynamo error that was happening, its how Revit works, with respect to IES files:
Your Revit.ini has a specific path to IES files. That’s the only way it will automatically “find them” by name only. Otherwise, it needs a full path.
So you’ll see in the two suggestions you got in the thread, one presents the IES name only, in the Set Parameter by name node, and the other presents the full path, at which point it is “found.” Coincidentally, if the IES file was in the location that was pathed on your machine, it may have worked with the earlier solution as well.
Sounds like a Revit issue, that masqueraded as a Dynamo issue (that then turned in to a personnel issue), but thankfully got solved anyway.
Hi Aron,
that’s true. in the Revit.ini is the path to the standard ies data. If one uses the “standard functions” of Revit, one can assign automatically also several types the suitable ies file. Unfortunately, this only sets a “link”. If another user does not have the same ies data under the same path. Then the family does not work anymore.
By hand, you can set the ies file but for each type (baking / integrate).
Well, it really seems to have been more of a revit problem.
Problem was solved.
A happy ending for all
