Using Rhythm to retrieve an instance parameter, I get this error.
Any idea?
Warning: Elements.GetParameterValueByNameTypeOrInstance operation failed.
The call is ambiguous between the following methods or properties: ‘Revit.Elements.ElementWrapper.Wrap(Autodesk.Revit.DB.CurtainSystem, bool)’ and ‘Revit.Elements.ElementWrapper.Wrap(Autodesk.Revit.DB.FamilyInstance, bool)’
It is a Structural Column Family (Revit 2019 - Attached )
I would like to read the Dimensions Parameters shown below
I am not finding any solution …MB_Frame_Vertical.rfa (332 KB)
Many thanks
